Xerox DC 12 paper problem
  • Ignis
    Problem is in when outputing on paper that is between 130-200 g. Paper came out all pleated..don't know where is problem.
    It happens on both standard offset kunstdruck and special printer kunstdruck (without glue and wood) paper. Same thing with Heavyweight or Extra heavyweight mode. Fuser was recently on reparation, upper pressure roller and some thermistors are changed.
    Picture is in attachment...
  • xcopytech
    • Aug 2006
    • 1794
    mail me
    you have problem with oil
    well known problem on dc 12 and such type of paper
    • TechMate
      • Mar 2008
      • 285
      You might want to check the OIL PUMP if it's working and the distributor if it's blocked. Also check the fuser nip gap (10mm-10.5mm)
      • artdigital
        check the oil pump
        hi there check the roller where is the oil, if the roller are dry tried put oil manual i think its the oil pump
        • Veedle
          Xerox Tech
          • Jul 2008
          • 44
          DC12's dont like litho/offset paper.
          They only work well on good quality coated copier papers that have a low moisture content - (litho paper has a higher moisture content and takes all the oil out of the rollers).
          You will need to replace the oiler assembly and the fuser roller and then set up the fuser nip to approx 10.3mm evenly across the page.
