Xerox wc 7125 error
  • landspeeder
    • Feb 2010
    • 355
    Xerox wc 7125 error
    The error is 092-315 any one have ideas??? Also does any one have a service manual??? sigh
    thanks
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • Exok
    • Jun 2011
    • 750
    Re: Xerox wc 7125 error
    Description
    The frequency at which the ATC Average Fail [K] or the ATC Amplitude Fail [K] has been occurring has exceeded the threshold value.
    NOTE:
    • Although this Fault can be cleared by turning the power OFF and ON and it will be possible to output a few sheets of printouts, when this Fault has occurred a certain number of times, it will no longer be clearable by turning the power OFF and ON. To clear it, clear the value of NVM location [752-368] (ATC Fail [K]) or NVM location[752-372] (ATC Fail Continuous Count [K]) to "0". If the machine is not repaired back to normal status, this Fault will occur again during the operation.
    • When turning the power OFF, turn OFF the power switch first and then the main power switch.
    Procedure
    Check the following:
    • The connection between the MCU PWB P/J411 and the CRUM Reader (K) P/J123 for open circuit, short circuit, and poor contact
    • The connection terminals between the Drum Cartridge (K) CRUM PWB and the CRUM Reader (K) for damage and foreign substances
    • The Toner Dispense Motor (C,K) for revolution failure: Component Control [093-004] ( PL 5.1)
    • The Drum/IBT Drive Motor for revolution failure: Component Control [042-001] ( PL 3.2)
    • The Main Drive Motor for revolution failure: Component Control [042-006] ( PL 3.3)
    • The Dev K Clutch for failure: Component Control [042-010] ( PL 3.3)
    • The path from Toner Cartridge (K) to Developer (K) for toner blockage
    • The Developer (K) for internal toner blockage
    • The Toner Cartridge (K) for internal toner blockage
    If no problems are found, replace the following parts in sequence:
    • adriansto
      • 2387
      Problem with readings from ATC sensor for K.
      Check K toner transport, K dispenser motor, K toner cartridge and developer for blockage, developer K clutch.
      • landspeeder
        • Feb 2010
        • 355
        Originally posted by Exok
        Description
        NOTE:
        Procedure
        Can it be a bad transfer belt as when the machine is running it makes a funny noise which when the belt is turned by hand it sounds the same!! Any chance of getting a service cd copy???
        Color copies are quite faint and black has prtetty much disappeared...comes and goes
        thanks
        • adriansto
          • 2387
          As I know the IBT dont have ATC sensor.
          Check inside of machine for toner, developer leakage or ,and for gears or clutchs contaminations with toner, developer.
          Service manual only in edoc format.
          • landspeeder
            • Feb 2010
            • 355
            can I get the edoc
            also thanks for the help!!
            • landspeeder
              • Feb 2010
              • 355
              I have GSNlock as we are Xerox auth. on a lot of models but not that one...and time is short on this issue!!
              • adriansto
                • 2387
                You need PWS for use the edoc.
                stoadis@gmail.com
                • xeroxsharp
                  • Nov 2008
                  • 270
                  thanks
                  Already work with this issue. Colour copies are good!
                  If you use another new black drum and get same resault / faulty main drive assembly
                  Main drive must be replaced / PN 007K16690 / FIRST TIME 1-2 hours of work
                  Fault can not be cleared by resetting chains 752-368 and 752-372 to 0
                  BR
