Workcentre Pro 32 - communication problem encountered
  • Szepo
    • Jun 2013
    • 6
    Hello everyone!
    I have a Workcentre Pro 32 Color. It displays communication problem encountered when turned on.
    I know there is this related thread http://www.copytechnet.com/forums/xe...countered.html
    But I have a different problem with the WCPS diagnostics software.
    I can connect to the machine but don't get any setup menu screen like that in post #4.
    http://www.copytechnet.com/forums/xe...tml#post164543
    Does anybody know how to fix my problem?
    Thanks in advance.
  • adriansto
    • 2392
    Re: Workcentre Pro 32 - communication problem encountered
    It is old WCPS version. Do you run it on WinXP and IE8 ?
    What is the software version on your WCP ?
    • Szepo
      • Jun 2013
      • 6
      I run it on WinXP 32bit and and IE8.
      Version PWS32 V01.02.029.
      Software Version WCP S0.01.02.030 on the module.
      • adriansto
        • 2392
        Use WinXP and IE6 or your software kit of WCPS it's not good
        Install a fresh WinXP, install WCPS and try again.
        I have the last version of WCPS which works with WinXP and IE8 or Win7 32 bit and IE8
        • Szepo
          • Jun 2013
          • 6
          Can you send me the software or give me a download link?
          Because I don't want to install windows new.
          • adriansto
            • 2392
            Sent you private message !
            • livewire
              • Sep 2011
              • 608
              Hello all, I support the position of adriansto. Last year I had the same problem. I changed my laptop and fix the problem.
              http://www.copytechnet.com/forums/xe...ator-wcps.html
              • Szepo
                • Jun 2013
                • 6
                Thanks.
                I have digged out my very old laptop and downgraded the IE8 to IE6.
                I give a feedback if that works.
                Edit:
                Yes it works, now.
                Thanks at both.
                • Szepo
                  • Jun 2013
                  • 6
                  I think I have screwed something up.
                  I tried to reset the machine but I don't find any function or button.
                  So I upgraded the software to (DC361 restore IOT critical NVM) S0_01_02.059 (but I have forgotten to save the old one). After the upgrade the UI has still the old version.
                  After a restart the unknown Fault in the WCPS fault list was gone but the display still shown "communication problem encountered".
                  Then I typed in the time and date in the WCPS (DC133). The machine restarted but the display still shown "communication problem encountered".
                  Next I initialized all aviable modules in (DC301, DC306). Then I clanged the Install Phaser (DC105) from Manufacturing to install Complete, and the system configuration unknown to Digital Copier - Printer.
                  Now the printer come with a new fault Configuration Mismatch exists.
                  In the menu DC303 the FDI Daughterboard Card Present is still an error. (I don't know what that is and if it is important)
                  Paper Tray Configuration Mismatch
                  Output Device Configuration Mismatch
                  EPC Memory Size fault.
                  I hope that somebody can help.
                  • adriansto
                    • 2392
                    Go back with the initial software version.
                    • Szepo
                      • Jun 2013
                      • 6
                      Did the Software made automatically somewhere a backup of the old version?
                      I searched for it but can't find an backup.
                      Because I don't have the old S0.01.02.030. I don't saved it.
                      • adriansto
                        • 2392
                        You cant save the software, there is not any backup.
                        You must have the software kit. In \xerox\WCPS\Data folder you have a save from machine critical nvm.
                        I have the sw version you need so you can send me a mail.
