Although it happens in the middle of the night, its probably not gremlins. I would check the condition of the registration clutch. You can also have 08-150 jams caused by the paper skewing as its being fed and then jams at the registration area. Have the user limit paper feeding to one tray at a time so see if its only jamming when being fed out of 1 of the paper trays. Trays 3 and 4 can develop paper cuts on the front-inside of the tray. These cuts can cause paper skewing / jams. You can sand these cuts smooth or install a tray rib kit (metal plates that cover the plastic ribs). Another thing to check is the drive for the vertical transport rollers. I often find screws that come loose (behind the waste toner bottle) for the plates that hold the vertical drive in place.
