service manual need how to go into wcpro 35 service mode
  • pc123321
    • Dec 2012
    • 103
    where can i download wc pro 35 service manual
    thanks
  • adriansto
    • 2383
    Re: service manual need how to go into wcpro 35 service mode
    thanks
    I have it but in edoc format.
    • bojans
      • 1313
      thanks
      Why do you need to go into service mode?
      • pc123321
        • Dec 2012
        • 103
        yes to see
        to clear the message replace waste toner box
        • seansbar
          • Dec 2010
          • 198
          you don't need service mode. Empty the bottle and make sure there is no residual toner in the area were the sensor "sees"
          • pc123321
            • Dec 2012
            • 103
            yes to see
            • pc123321
              • Dec 2012
              • 103
              yes to see
              i try two new clean unused well pack box ,inside waste toner box , give me the same message ,
              yesterday i try once disassembly the power unit and put it back ,test ,give me the same message ,
              tomorrow i try again
              the whole unit gear transfer i took out before ,there are two small screw fasten to the sensor frame (left side white plastic sensor cover)
              sensor frame position will change ,it depend on two alignment screw holes
              • bojans
                • 1313
                Check PM!
                • pc123321
                  • Dec 2012
                  • 103
                  Check PM!
                  the waste toner box door switch , i used wire to short circuit then the screen message only replace toner box
                  the fault error code 09-380 disappear , but the screen message is replace waste toner box 03-700,03-785 only power
                  to continue check out ----tomorrow reseated the waster toner box switch
                  • efe311
                    • 114
                    thanks
                    # & key password is 1943
                    & make initial its work
                    i make it many times
                    • pc123321
                      • Dec 2012
                      • 103
                      machine turn on --
                      self test
                      network test ---
                      how did it # and 1943-
                      or turn on machine and press # at the same time ? then key in 1943 ?
                      • livewire
                        • Sep 2011
                        • 608
                        # and Access key,
                        Enter 1934
                        • KHALEDGAD77
                          • Jan 2012
                          • 11
                          hi efe311 i am khaled from egypt 01223877289 can u tell me
                          • pc123321
                            • Dec 2012
                            • 103
                            test the three pin voltage from pwb
                            orange---black 1.7v
                            orange ---vio 5v
                            black ---vio 3.3 v
