I have replaced the fuser heat roller motor, and replaced the heat roller, bearings, and pressure roller.
I still got the code 10-330 ( fuser motor fail).
I loosened the pressure roller bolts ( front and back) almost all the way.. now it runs... but may fault out 10-330 at any time.. between 100 copies or 500 copies.
i have had to adjust the bolts to try to get the nip right. Are their any suggestions on what to do?
I guess i have to check voltages next.
