ColorQube 9303 error 093-871
+ More Options
Posts
  • jmandassociates
    • Sep 2008
    • 186
    Need help with a ColorQube 9303 saying "Ready to scan. copying and printing not available. system fault. call for assistance quoting error code 093-871" Also does anyone have the service and parts manuals for this?
  • DFM914
    • Jun 2010
    • 73
    Re: ColorQube 9303 error 093-871
    Fault Code 093-871: Black Melt Reservoir Level Sense Failure
    Fault Code 093-871: Black Melt Reservoir Level Sense Failure . Power the Machine Off and On Using the Quick Restart Option .
    • dorez
      • Feb 2013
      • 73
      The error code message is correct however to fix is not..
      You most likely have cross ink contamination, which is caused by not following the "Please Wait 30 Minutes Before Moving' Rule. If this is the case sometimes you can clean the contamination but 99% of the time it's time for a new ink reservoir. Part# 604K67923.
      The Other .1% its to replace the Marking unit driver pwb; part# 960K46440
      Hope This Helps..
      • JustManuals
        • Jan 2006
        • 9838
        I just got that manual today. Email me.
        Paul
        • Exok
          • Jun 2011
          • 750
          The only thing I've experienced to fix this type of error is replacing the ink reservoir. Not necessarily due to contamination from moving the machine while the ink is still in liquid form but that is one way to mess up your color qube. The reservoir could have just failed on its own. I've probably replaced a dozen or more since being trained on this machine.
          • dorez
            • Feb 2013
            • 73
            Every time I see these this is always the reason; moving which ink is still in liquid form. Also when I look in the service book, I always see reservoir replaced at least once if not more.
            • jmandassociates
              • Sep 2008
              • 186
              The error code finally just went away now it is stuck on "Please wait printer cleaning in progress. We have left it on for hours and it never gets past that.
              • dorez
                • Feb 2013
                • 73
                Do you have a finisher hooked up to it? As this machine will require the finisher to complete any printing including the cleaning pages. I had the same problem hooked up the finisher and it completed the cleaning within seconds.
                Hope This Helps.
                • Exok
                  • Jun 2011
                  • 750
                  You might still be in a fault condition. It just might not be showing on the screen right now. You can look up the fault history on the display screen and it will show you a list of recent faults with the date and time it occurred. I had a 9303 with this fault just last week and I replaced the ink reservoir to fix it.
                  We use rebuilt reservoirs from xerox. Its less money. The part # is 622S01401.
                  • dorez
                    • Feb 2013
                    • 73
                    So true this is, we had a machine here that one of the techs told me it had this error code then it "went away" so he assumed it fixed itself.. LOL Then few days later double checked it then gave error again, I just laughed and he said well it must have broke again.
                    Thanks for the Part#! This should help save some $$.
                    • jmandassociates
                      • Sep 2008
                      • 186
                      I have tried to clear the fault codes but haven't been able to. I went into service mode and to Call Closeout and the only thing that shows up is the reset waste counter and reset counter. Not Faults and Last 40 faults.20130827_162947.jpg
                      • dorez
                        • Feb 2013
                        • 73
                        I have tried to clear the fault codes but haven't been able to. I went into service mode and to Call Closeout and the only thing that shows up is the reset waste counter and reset counter. Not Faults and Last 40 faults.[ATTACH=CONFIG]21855[/ATTACH]
                        I see not finisher is hooked up, this machine REQUIRES a finisher to be hooked up for all printing, if you do not have a finisher you can use a bypass tool. The "cleaning reports" will not print without a finisher or finisher bypass hooked up.
                        Did you fix the ink reservoir since the last post?
                        • jmandassociates
                          • Sep 2008
                          • 186
                          I didn't replace the ink reservoir yet. Is there any other way to clear the faults without hooking up the finisher. The finisher is another problem that is not working either.
                          • alex23845
                            • Aug 2013
                            • 19
                            Can somebody help with service manual for 9303? Thanks in advance.
                            • Lee2475
                              • Oct 2014
                              • 48
                              you either sort the finisher out, or put a cheat in the back.
                              it will do nothing until you sort that.
