ColorQube 9303 error 093-871
  • Lee2475
    • Oct 2014
    • 48
    #16
    Re: ColorQube 9303 error 093-871
    what finisher you got and what's up with it?
    • aikon
      #17
      Anyone Knows about error 092-805? I can't find nothing about this error! Thanks
      Xerox Colorqube 9303
      • JrTech
        • Jun 2013
        • 217
        #18
        As mentioned in the previous posts, you are better off purchasing a new one. There are 2 part numbers located on the 1st page of the post. Either or will work, just call around where you are to see who has it. There is a company located in Northern VA called Item Inc or NJ called The Parts Drop that has these in stock. PM me and I will send you the instructions of how to do this procedure.
        93-871-00 Black melt reservoir level sense failure.
        93-872-00 Magenta melt reservoir level sense failure
        93-873-00 Cyan melt reservoir level sense failure
        93-874-00 Yellow melt reservoir level sense failure
        Hope this helps
        • JrTech
          • Jun 2013
          • 217
          #19
          Sorry about last post it pertained to the error code on the original thread. Ok here is your error code.
          93-805-00 Head 3 black reservoir level sense short circuit
          This is a tricky one but if your willing to tackle, by all means. I would suggest that you look at the PrintHead, the Printhead cabling or the MU heater pwba. This could be something simple as a piched wire. Was there a jam in the machine prior to this happening? What was the machine doing when it stopped to give the code 93-805-00?
          Hope this helps
