5655 Touch Screen Calibrate
  • mrfuser
    • 1622
    Brain dead, forgot how to calibrate touch screen on the 56xx series.
    Any help?
    Kelly
  • Exok
    • Jun 2011
    • 750
    Re: 5655 Touch Screen Calibrate
    1. To access Set Up Menu (UI Diagnostics) press and hold in sequence the "dial pause" "*" , then "#" (dial pause-star-pound) buttons then release all at the same time.
    2. Press the Dial Pause button to access the UI Alignment procedure, called "Calibration Mode".
    3. The instructions say to Press P1, P2, P3, etc.
    4. Important-Press the point where the lines intersect each other for an accurate alignment. Use a pen tip to precisely select the alignment location. Press lightly to prevent UI screen damage.
