Fax settings for Fuji Xerox Apeos Printer
  • Wen Le
    • Sep 2013
    • 13
    Dear,
    When it comes to set the fax settings for a printer (e.g. Fuji Xerox Apeos Printer), how best to set the following NVM in order to achieve an optimal level where it can receive overseas incoming faxes smoothly most of the times? The transmission speed must be optimal (not too slow or too fast) and it must allow to receive the overseas incoming faxes smoothly & also for outgoing fax to overseas. I heard that it is necessary to take into account "speed synchronization" for the sender's fax machine and receiver's fax machine when it comes to transmitting a fax smoothly. But, the problem is that we do not know what is the speed or other settings at the sender's fax machine from overseas.
    825 – 128
    Sending out level
    825 – 252
    G3 Rx cable equalizer for channel 1
    825 – 277
    Incoming level
    823 – 050
    Ring detect frequency (no of rings)
    825 – 228
    Speed in transmission
    825 – 216
    Speed in reception
    If there is any other NVM that is not stated above but you think it is important or necessary, please include and indicate. As far as I know,the nos to key in could be 0 (disabled), 1 (enabled) or from a range of 0 -9 or even more (from minimum to maximum). If you decide to set a certain number, if possible, please explain why it is necessary to set at this level or with this number.
    Thank you for your sharing and advice.
  • Wen Le
    • Sep 2013
    • 13
    Re: Fax settings for Fuji Xerox Apeos Printer
    I got some tips for the following two days ago. Rather than increasing or decreasing the values, an engineer advised to use the default settings and monitor how well the fax connection with overseas works. This is the baseline for proper functioning of fax connection. Please note that the no for default or the various NVM could vary depending on the type of models.
    NVM
    Default
    825 – 128
    Sending out level
    8
    825 – 252
    1
    825 – 277
    Incoming level
    1
    823 – 050
    0 time
    825 – 228
    8 (14400bps)
    825 – 216
    Speed in reception
    8 (14400bps)
    • ApeosMan
      • Nov 2009
      • 183
      Try posting this in the Xerox part of this forum.
