xerox wc pro 35 scaner initial fail scaner error
  • pc123321
    • Dec 2012
    • 103
    xerox wc pro 35
    1.error code 14-110
    copy and scaner unavailable
    is that scaner sensor error
    2. document handler unavailable ---
    two messages shown on screen
    second message always shown on message
    the reason is ?? we put some paper on the top of machine
    any advice are welcome
  • JustManuals
    • Jan 2006
    • 9838
    Re: xerox wc pro 35 scaner initial fail scaner error
    Do you think that posting this twice is going to get you an answer any faster?
    • pc123321
      • Dec 2012
      • 103
      sorry , computer running slow
      hit twice
      • livewire
        • Sep 2011
        • 608
        Hi, check here:
        http://www.copytechnet.com/forums/xe...nitialize.html
        • Leodis_UK
          Sounds like the scanner pwb has failed. Needs a qualified engineer as the new scanner pwb must be fitted in exactly the same place as the old one. Only alternative is to replace the whole scanner. This only affects the 32-38ppm mfp's as the resistors burn out.
          • pc123321
            • Dec 2012
            • 103
            hit twice
            don't know why the message shown on the screen for 3 days
            this morning still there ,afternoon turn it off and then restart it
            error message are gone like nothing happen
            • nilak
              • Aug 2010
              • 72
              There are few possibilities but depending what you wrote, it looks like your CCD PWB has "back loop" ballast resistors burnt out(5v gen.). Original ones -3x 10 ohms 0.125w should be replaced by 0.5w ones. On the other side of PWB some times you have a 131 0hm surface mounted R that is gone too (collateral damage)- replace it with available one ( chosen from E12 130 ohms 0.125w would fit ), damaged traces should be repaired also! The chances are about 65%. If you feel uncertain don’t try it. The easiest way is to replace the whole scanner!
