DC252 Magenta marks
+ More Options
Posts
  • fatfingers73
    • Feb 2013
    • 219
    DC252 Magenta marks
    Hello all,
    I'm having trouble with this problem. Getting magenta marks across the top of each page.
    Machine has had new devs a drums.
    Machine is dumping dev and toner everywhere.
    I vac it out and it prints fine for a few copies then the marks return.
    Any ideas? Many thanks.
  • fatfingers73
    • Feb 2013
    • 219
    Re: DC252 Magenta marks
    Anyone?
    Also any idea why jpeg wont show?
    Thank you and happy Wednesday.
    • InterfaceP
      • Jun 2013
      • 488
      I cant see the pic, take another and also include one of the M developer unit with the drum removed.
      • fatfingers73
        • Feb 2013
        • 219
        Thanks for the reply. I've asked client to send me pic. What are you looking for?
        None of my pictures are uploading, tried a few formats, is there a problem with pics?
        Cheers.
        • InterfaceP
          • Jun 2013
          • 488
          You may need to use a third party site for the pics.
          I'm thinking something is broken. The developer unit has a piece that runs along the developer housing that controls the amount of developer/toner that contacts the drum.
          You say it spills toner and developer?? Sounds strange are you sure its developer? You can easily tell by using a magnet or by the weight.
          Good luck!
          • fatfingers73
            • Feb 2013
            • 219
            Hello,
            Yes dev is piling up at the back of the machine on 2nd transfer unit and duplexer. There's also a band of toner around the back on the transfer belt (all magenta).
            The dev on the mag roller is higher at the back end of the roller, can the mag roller come out of position? The gears seem fine, machine has only done 300k.
            Don't have a spare dev tank to try, and machine is out of warranty.
            Thanks again for your time. I'll sign up for a 3rd party image site later.
            Good luck!
            • fatfingers73
              • Feb 2013
              • 219
              Client has just sent pic of mag dev tank. Roller has no dev on rear 3 inches.
              Is it possible dev tank has failed? Wouldn't that give me a fault code.
              Normally only work on sharp and ricoh and dev dump would just be a charge issue.
              Any help appreciated.
              Cheers.
              • Exok
                • Jun 2011
                • 750
                Did the machine have this same problem before the magenta developer and drum were replaced or is this a new problem after they were installed?
                Did you verify if the machine is level front to back? Gravity can be a bitch on an uneven floor.
                • fatfingers73
                  • Feb 2013
                  • 219
                  Hi, he said it started when he fitted new drums, I have tried swapping drums but fault stays with magenta.
                  Floor is level.
                  Thanks for your input.
                  • InterfaceP
                    • Jun 2013
                    • 488
                    OK, I think you should open up the M dev unit to see whats going on. You may have a "toner rock" inside clogging things up.
                    Remove the M drum>Remove the screw and cover exposing the electrical connector disconnect it> Remove two 5.5 mm screws located in the front and rear of the dev
                    unit>Remove the cover.
                    The auger should be full of toner in the first chamber, and dev. in the second (right to left) Ensure the auger moves freely and has no obstructions. You can also remove the
                    leveling bar that runs across by removing the two Phillips head screws. This controls how much developer comes out of the unit. If it's not properly seated it could allow too
                    much developer to come out.
                    The developer unit isn't parted out.
                    Good Luck!
                    • fatfingers73
                      • Feb 2013
                      • 219
                      Thanks but I changed dev while I was there. Vacced out the dev unit completely, checked gears and mag roller (is that called auger on these?).
                      Nothing appeared out of place.
                      Wish I had another dev unit to try!
                      Thanks for the advice.
                      Good Luck!
                      • fatfingers73
                        • Feb 2013
                        • 219
                        Returned to have another look at magenta dev unit. Leveling bar looked good, really stumped!
                        Going to try another dev unit.
                        Thanks.
