5655 two sided dark copy
  • mrfuser
    • 1622
    Ok client can run one sided all day fine. Start to run two sided and they get darker back ground as it goes. We replaced feeder and drum unit and same result.
    Only happens with multiple originals, single two sided is fine even with multiple copies run of one original!
    any ideas?
    kelly
  • xeroxsharp
    • Nov 2008
    • 270
    Re: 5655 two sided dark copy
    What I will do first.
    -very good scaner cleaning
    -replaceing scaner pwb and exposure lamp
    -sw upgrade!
    -IOT pwb
    PS
    is the same problem if you make two sided copies/scans from glass,or if you make two sided prints?
    Regards
    • andywong90
      • Mar 2013
      • 110
      you can try chg developer...
      • mrfuser
        • 1622
        Bad exposure lamp. Replaced and all good.
        • andywong90
          • Mar 2013
          • 110
          YOU can try chg deverloper unit...
