xerox dc5000
  • ramyaselvam
    • Jan 2013
    • 6
    xerox dc5000
    can anyone help me my dc 5000 shows print engine sub system fault 6-332
  • vibin
    • Sep 2011
    • 38
    Re: xerox dc5000
    How did you get this error. Did it just start all of a sudden. Also 6-332, is this the correct number. Please confirm.
    • ramyaselvam
      • Jan 2013
      • 6
      Re: xerox dc5000
      Originally posted by vibin
      first the m/c shows fuber web loaded incorrectly then i just open & close the feeder it becomes ok then i given my print this error comes
      after all from the m/c the fan sound is not come from the beginning
      • vibin
        • Sep 2011
        • 38
        Re: xerox dc5000
        HI,
        Do you have another fuser web? Try to change it.
        Also which is the error number as i dont have that error (6-332) on my PWS.
        • ramyaselvam
          • Jan 2013
          • 6
          Re: xerox dc5000
          HI,
          the fuser web is already a new one
          i check that fault code on web it shows sos stop fail (YM)RAP ,dc330 code to check polygon motor on YM listen for polygon motor to enerzise
          • vibin
            • Sep 2011
            • 38
            Re: xerox dc5000
            Please send me the exact error code. so that i can check for you on my PWS and get a solution.
            Vibin
            • adriansto
              • 2392
              Re: xerox dc5000
              Check the wires from YM ROS
              Go diagnostic and run 006-030 from DC330. If you hear the polygon motor then the SOS sensor from YM laser is gone and you need to change YM laser assy.
              If the motor not heard then may be the YM laser defect or MCU PWB defect
              • adriansto
                • 2392
                Re: xerox dc5000
                Vibin
                Seems you dont have the right manual.
                6-332 is the fourth procedure from Chain6 from chapter2 from 705P01253 DC5000 edoc.
