Xerox 560 metered/non metered help!
  • ruimestre
    • Mar 2012
    • 36
    [Dead] Xerox 560 metered/non metered help!
    Hi thank you for your attention
    my machine xerox 560 (superb machine) has ended the contract
    i have lots and lots of consumables but what I wasn't expecting was that the machine a the end of the contract turned automatically from metered consumables to no metered.
    now the machine is dead because it doesn't accept the consumables I have.
    It required a pin activation for page pack
    i would appreciate if someone could give me some ideas or solutions.
    Thank you all in advance!!!!
  • zeeeba
    • Dec 2012
    • 58
    Re: Xerox 560 metered/non metered help!
    This thing was happened because, when You have contract Your supplies was with metered contract type, when Your contract ended your machine has been changed to sold contract type. I think you need Contact Technical Support Center or your NTS for the CRUM conversion procedure. Only they can change contract type to neutral and when Your machine can use metered or sold contract plan supplies.
    • ruimestre
      • Mar 2012
      • 36
      • zeeeba
        • Dec 2012
        • 58
        PM me, maybe we will find the solution together
        • adriansto
          • 2388
          Originally posted by ruimestre
          Last chance will be buying chips for non metered toner.
          i was hopping for a nvm solution or something.
          Thank you all for your atention.
          The chips solutions is the proper one at this time.
          You can use also the sold type consumables for 550 / 560 machine
          You also need to find someone to servicing your machine. For Europe zone if you do a NVM init or reload the machine software you need the PIN activation code and that you will be obtain only from Xerox.
          • ruimestre
            • Mar 2012
            • 36
            Again thank you all for your support and interest.
            i have a xerox 240 and a 250 both in top condition I do the servicing for quite sometime now
            but the xerox 560 I have bought used, is superior in some jobs and I have some jobs that
            can only be printed on the 560
            Until now the only thing that I've been afraid is a software problem on my machines
            mechanical I can handle but software such as this one (machine automatically switched from metered to
            non metered toners and maybe drums), is giving me quite a challenge.
            One more question to buy chips, anyone knows a good supplier
            I know rechargestore, AAAtoner....
            Thank you all very much.
            • ruimestre
              • Mar 2012
              • 36
              Just to inform that the problem is solved.
              changing the chips ; )
              thank you all
              • valemaui
                • Dec 2021
                • 1
                thank you all
                Hi, I have the same problem with my XEROX J75 color press... Can someone describe to me the procedure to be able to reset the PAGE PACK PIN and get the machine working again without codes?
