WC5230 pws diagnostic tools required
+ More Options
Posts
  • Guest
    hi,happy new year
    Does anyone have pws diagnostic tools for wc5225/5230.I need it urgently or exchange Canon service manuals.
    yimsangiam@hotmail.com
  • Exok
    • Jun 2011
    • 750
    Re: WC5230 pws diagnostic tools required
    5225 /5230 diagnostics are accessed through the UI.
    Hold the 0 key for 6 seconds then press Start.
    Enter access # 6789 and Confirm.
    To access diagnostic routines:
    Press the Machine Status button.
    Select Tools tab.
    Under Features column, use the down arrow and scroll to the Maintenance / Diagnostics.
    You can access:
    NVM read / write.
    Sub System
    - HDD initialize
    - HDD Failure Prediction Test
    - Delete All Data
    - Software Options
    - Fax Diagnostics
    Print Test Pattern
    Max Set Up
    Initialize NVM
    Adjustments / Other
    - Machine ID / Billing Data
    - Initialize HFSI Counters
    - Tray 5 (bypass) Guide Adjustment
    Faults
