workcenter 7346, started with error 116-317
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    First of all, i am a Konica tech. i am on this machine because it is probably the only one on base, and they have no service contract and I am the only one around who gives free est.
    I tried to tell the customer that without great tech support, I am guessing and parts will not be returnable.
    They said that it started with the error 116-317, and would tell them to reboot. Rebooting does nothing. Customer did online research that pointed to the logic board. They pulled the board and reseated everything. Now when the machine is turned on, blue screen comes up, and 1 piece of the white bar at bottom of screen shows up, then the machine is stuck on that screen.
    My gut feeling on this is to run from it, but they are in a bind. Being military, they have a hard time getting new stuff, but can fix what they own, up to a point.
    When I checked online, one forum pointed to memory, but that was for the code, not the blank screen.
    Is this worth my effort, or is it a money pit. I also removed the board and ensured everything was seated after they had pulled it.
  • Flash
    • 378
    Re: workcenter 7346, started with error 116-317
    It is the 1G memory on the network controller board. I will look up the part number and get back with you.
    • Exok
      • Jun 2011
      • 750
      It is the 1g memory dimm. You don't need a xerox specific dimm though. Pop it out and replace it with one of the same type from any computer hardware seller.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Thank you both for your input. I told the customer I wasn't going to do anything until at least 2 techs agreed on what the solution was. I will try to find a dimm today and will post the results.
        • adriansto
          • 2387
          Before replace 1Gb memory reseat all verticaly and horizontaly DIMM's from network controller board.
          Then perform nvm init = press and hold the 3, the Stop, and the Power Save buttons simultaneously , power on the machine and keep the buttons pressed until the segment bar appears on display.
          If , after replacing the 1GB memory, the fault remain you need to reload machine software.
          • fixthecopier
            ALIEN OVERLORD
            • 4713
            Thanks to all of you, I have added to your rep.
            Had a dimm at the shop, installed it and preformed the nvm int and the machine came back to life. Was a little worried when the top of the control panel would not respond to touch, but after about 6 or 7 minutes it was fine. Again, thanks to you all.
