Xerox 7345 Fault Codes 062-380 and 005-122 - is this a bad lamp?
  • patterson70
    • May 2010
    • 601
    Hello, I have not been to the customer site yet but they report two fault codes 062-380 and 005-122 coming up. I checked these codes and it appears this is scanner-related. I asked and the customer says the scanner light does not come on when it powers up. I would just like to ask if anyone could verify so I can order the part and have it with me when I go there. Thanks in advance for any help!
  • patterson70
    • May 2010
    • 601
    Re: Xerox 7345 Fault Codes 062-380 and 005-122 - is this a bad lamp?
    This turned out to be a bad fuser that was overheating - I had not been to the customer site and was trying to diagnose by the fault codes which were not much help, not sure why the scanner faults show up but that's what happened.
      • 23009
      Thanks for posting back an answer. I'm sure this will help somebody. =^..^=
