Xerox 5765
  • azehnali
    • Nov 2009
    • 679
    Xerox 5765
    does anyone know the activation code to enable network controller
  • Exok
    • Jun 2011
    • 750
    Re: Xerox 5765
    The network controller does not need to be activated with a code. Its a standard feature of the machine.
    • azehnali
      • Nov 2009
      • 679
      Re: Xerox 5765
      not on this one
      it has all the hardware there but says network controller not enabled
      it requires a passcode to enable it
      • Exok
        • Jun 2011
        • 750
        Re: Xerox 5765
        Is it a WorkCentre 5765 or a Majestic 5765 ?
        • azehnali
          • Nov 2009
          • 679
          Re: Xerox 5765
          The machine is not in a cave
          its a workcenter 5765 not a majestic
          lol
          Bottom line is that it needs the activation code
          • Exok
            • Jun 2011
            • 750
            Re: Xerox 5765
            Sorry, I never heard of a WC5765 asking for a network activation code.
            I wold recommend doing a forced AltBoot first.
            • azehnali
              • Nov 2009
              • 679
              Re: Xerox 5765
              did that
              when it come to network controller portion it skips it
              • Exok
                • Jun 2011
                • 750
                Re: Xerox 5765
                OK, sorry I couldn't help you. I'll see if I can come up with something tomorrow.
                • azehnali
                  • Nov 2009
                  • 679
                  Re: Xerox 5765
                  thanks
                  I am 99.9999999999999999999% sure it needs the activation code in tools
                  • adriansto
                    • 2388
                    Re: Xerox 5765
                    Originally posted by azehnali
                    thanks
                    Upgrade from Copier to Multifunctional machine is a payable option.
                    You pay and you get the activation code only from Xerox
                    • Exok
                      • Jun 2011
                      • 750
                      Re: Xerox 5765
                      I knew the 56xx had different versions (stand alone copier and Copy/Scan/Printer). I never came across a stand alone 57xx but checking out the standard features vs optional features at xerox.com, that is how they come if you don't buy the upgrade. Did this machine originally have scan/print option or are you just looking for a work-around to get features that were not paid for?
                      • azehnali
                        • Nov 2009
                        • 679
                        Re: Xerox 5765
                        dont worry
                        I have hundreds of other ones
                        this one was sold already as a copier only
                        thanks
