Xerox DC12 System Fault 6-355
  • JimmyB
    • Jun 2008
    • 77
    I have Xerox DC12. When I turn on printer, It display an error code 6-355 .
    Could, anybody help me, what it means?
    Thanks in advance.
  • JimmyB
    • Jun 2008
    • 77
    I have found that
    6-xxx Codes relate to the optics ,
    but what exact is 6-355?
    • xcopytech
      • Aug 2006
      • 1794
      6-355 IPS fan error
      check ips fan if not work replace it
      • sachin
        • Jun 2008
        • 13
        DC12
        IPS fan problem :
        Enter dc330 (06-013) Press start
        does fan rotates ???
        contact me on : agrwalsachin@gmail.com
        • TechMate
          • Mar 2008
          • 285
          If the PRE IPS FAN is working, you may need to check the WIRE from IIT/IPS PWB (P/J722-B10) to IPS fan connector (P/J738-3). Replace if there is no continuity
