Xerox WC 5638
  • sergejs
    • Jun 2025
    [Misc] Xerox WC 5638
    We`ve got communication error code 1 on machine WC 5638 through NVM save and restore tool. Battery was changed on software module because of power 2.8 V. No possible to change value of NVM 03-021. We`ve made USB procedure G28 and initialization of all NVM, but still device can`t connect with computer. U7 wired with Software module.
    Is there any solution to connect the device with peripherials???
  • adriansto
    • 2384
    Re: Xerox WC 5638
    Is this copier only or copier printer machine ?
    What machine sw. version have?
    • sergejs
      Re: Xerox WC 5638
      It`s printer and copier, machine software version - 25:054:65:212
      • adriansto
        • 2384
        Re: Xerox WC 5638
        Remove the yellow battery from software module for 20 minutes time.
        Put it back and do forced altboot procedure.
        Do you have the right version of the pws tool for this SBC machine ?
        • xcopytech
          • Aug 2006
          • 1792
          Re: Xerox WC 5638
          Turn off usb port on machine.
          When usb port is off you can use it for diagnostic.
          When usb port is on then customer can print through usb port.
          • adriansto
            • 2384
            Re: Xerox WC 5638
            This is exactly the GP28 procedure he claim was made.
            • xcopytech
              • Aug 2006
              • 1792
              Re: Xerox WC 5638
              Have a same problem.
              Could not establish usb conection with tool version 25.00.012.
              Install older version 25.00.011 and then was able to connect to machine.
              Also for SBC machine must have at least 25.00.005 pws tool.
              • sergejs
                Re: Xerox WC 5638
                1) It` not possible to downgrade tool version
                2) Allboot cant`t connect, just the same communication error
                Also we did all procedures adriansto mentioned.
                • adriansto
                  • 2384
                  Re: Xerox WC 5638
                  Did you try altboot procedure using Usb stick ?
                  The latest good pws diagnostic tool is 25.00.0011.
                  Do you have 5V and 3.3V on SBC board ?
                  • xcopytech
                    • Aug 2006
                    • 1792
                    Re: Xerox WC 5638
                    Latest pws tool is 25.00.0012 as you can see in attachment.
                    It is possible to install older pws tool, but first, you must uninstall current version.
                    Did you disabled antivirus software and wifi on your laptop.
                    Did you tried alboot from usb stick or from PWS laptop?
                    • livewire
                      • Sep 2011
                      • 608
                      Re: Xerox WC 5638
                      Try to connect with another PWS (laptop).
