4110 Restarting
  • davidj7
    • 1107
    4110 Restarting
    HI
    My 4110 which was working perfectly fine till closing yesterday . It keeps on restarting when the power is turned on .
    I opened the front door and powered it . Then everything comes fine but after i close the door it restarts again.
    I cleaned the RAM's . besides that i donno what to do or look . Any ideas.
  • adriansto
    • 2387
    Re: 4110 Restarting
    Serach in 4110f_sources_V318 CD or in eureka tips
    You'll find a lot of checkings.
    • davidj7
      • 1107
      Re: 4110 Restarting
      i serached in eureka but I couldnt find anything close
      on an update :
      I disconnected the Internal RIP cable and turned on the machine . It does not restart but gives me a different window . SO now i am thinking what I have is a corrupt software on the RIP.
      I have system software 3.0. Is the Rip software included with system software or should i start looking for something else.
      • adriansto
        • 2387
        Re: 4110 Restarting
        If your machine is copier printer then you have fuhjin-XC-ps-dld-1.202.6.bin file into version 3 software package. This is the controller software file for internal rip.
        If you have external RIP or dfe kit installed then you need the separate software for the DFE.
        • davidj7
          • 1107
          Re: 4110 Restarting
          yes i have that file . :-) thanks a ton
          • davidj7
            • 1107
            Its not RIP related. can you can think of anything else ?
            Edit : If i pull the feeder out of the machine(fixing duplex all) , cheat the switches then it wont restart . So i am thinking there is some short circuit in feeder unit ?
            Sent from my Nexus 5 using Tapatalk
            • adriansto
              • 2387
              Re: 4110 Restarting
              I will started monitoring the voltages on the LVPS.
              Also cleanning the power connectors.
              • Exok
                • Jun 2011
                • 750
                Re: 4110 Restarting
                I suspect the power supply.
                • seansbar
                  • Dec 2010
                  • 198
                  Re: 4110 Restarting
                  I have had several door interlock switches fail on me. Its worth a look at.
                  • davidj7
                    • 1107
                    Re: 4110 Restarting
                    Can I have the part # for the interlock switches. I couldn't locate it on the PL
                    edit :bad me just the desperation . I located the Part # ordering it
