Workcentre 5150 Devo Change
  • SDtech619
    • Dec 2013
    • 40
    [CQ] Workcentre 5150 Devo Change
    Hey all,
    I need to replace the dev unit and developer...not a Xerox pro nor do I have any edocs. Is this just a plug and play or is there anything I need to do without edocs?? Initializations??
    Thanks in advance.
  • adriansto
    • 2387
    Re: Workcentre 5150 Devo Change
    If you buy new dev unit it comes with developer inside. Put the toner dispense unit from old dev unit to the new one. Go to diag mode and execute dc905 routine after you set dc131 09-271 at 0 value.
    If you change only dev material ( 1 Kg= 1 bottle ) follow same procedures.
    If you need SM send me mail at stoadis@gmail.com
