info machine choice
  • Enzo
    • Jul 2009
    • 413
    info machine choice
    Hello my friends. Should I buy a machine. I wanted to get some advice from you. The machines to choose from are:
    - WorkCentre 5645
    - WorkCentre 5655
    - WorkCentre 245
    According to you, which is the best? thank you very much
  • xeroxsharp
    • Nov 2008
    • 270
    Re: info machine choice
    All are almost the same.
    WC 245 is the oldest model ( 7 years + )
    WC 5645/55 is a little younger ( 5years + )
    This is very good BW series
    XEROG MODUL, FUSER,TONER are the same in both models
    All my customers are very satisfied with this series.
    I have more than 50 in the field,and they works fine.
    Regards
    • Enzo
      • Jul 2009
      • 413
      thank you very much my friend. You gave me good advice. although after having bought the machine, I would have the problem of where to buy supplies! here in Italy are found hardly!
      • xeroxsharp
        • Nov 2008
        • 270
        drum unit for 400K - around 200eur
        fuser unit for 400K - around 300eur
        toner for 50-60K - around 160-200 eur
        Check europa EBAY,but good price is easy to find if you use PN of each consumable.
        Regards,
        • Enzo
          • Jul 2009
          • 413
          thanks friend. "PN" What does it mean?
          • Blizzoo
            • Aug 2013
            • 608
            Part Number,every consumable have a specific PN.
            Happy Easter
            • Enzo
              • Jul 2009
              • 413
              Happy Easter
              ah ok ok. I had not understood immediately! thanks
              • Enzo
                • Jul 2009
                • 413
                hello friends. you can tell me the consumables oem code for XEROX 5655? (example: toner, xerographic module and fuser).
                The machine is European.
                thanks
                • Enzo
                  • Jul 2009
                  • 413
                  thanks
                  anyone who can help me?
                  What is the difference between metered and sold?
                  What does it mean: XE / USSG / XCL ?
                  I need to buy toner, xerographic module and fuser suitable for my machine (XEROX 5645).
                  • livewire
                    • Sep 2011
                    • 608
                    Hi Enzo,
                    Metered = Contract with Xerox
                    Sold = Non-Contract
                    XE =
                    Xerox Europe
                    USSG = United States
                    Solutions Group
                    XCL =
                    Xerox Canada Limited
                    Materiali di consumo, toner e accessori per WorkCentre 5645/5655 Stampanti multifunzione laser in bianco e nero
                    • imihm
                      • Feb 2014
                      • 77
                      Originally posted by livewire
                      Hi Enzo,
                      Sold = Non-Contract
                      XE =
                      Xerox Europe
                      Solutions Group
                      XCL =
                      Hi all
                      Although 5645/5655 mostly use the same parts and consumables but i
                      think 5655 is better speed wise as the last two figures indicate the speed
                      thanks
                      • Enzo
                        • Jul 2009
                        • 413
                        Hi Enzo,
                        Sold = Non-Contract
                        XE =
                        Xerox Europe
                        Solutions Group
                        XCL =
                        thanks for the reply, my friend. so I'm having a European machine should I look for material code "XE".
                        • Enzo
                          • Jul 2009
                          • 413
                          hello friends. I have some questions for you regarding the xerox machine wc5645.
                          1) How to go from 5645 to 5655?
                          2) It is possible to have the ALTBOOT for this machine? obviously also have the instructions for how to reload the software.
                          I would already be prepared in the event that the machine had a problem, what kind of network controller. you helped me so much with the reload of the software for dc440st! thank you very much
                          • Enzo
                            • Jul 2009
                            • 413
                            Hello friends. I have a problem of access to the diagnostic menu of xerox wc5645.
                            when I enter code: 1934 the machine shows me the error that the code is wrong. How can I fix?
                            • KHALEDGAD77
                              • Jan 2012
                              • 11
                              hi enzo u can reset softwere remove a yallow battry from nvr 15 mint
