info machine choice
  • Enzo
    • Jul 2009
    • 413
    #16
    Re: info machine choice
    Originally posted by KHALEDGAD77
    hi enzo u can reset softwere remove a yallow battry from nvr 15 mint
    ok thanks friend. I will follow your counsel.
    • Enzo
      • Jul 2009
      • 413
      #17
      Hello friends. On my wc5645 where I can check the really copies made? (I mean you know what nvm I have to check). Thank you very much
      • xcopytech
        • Aug 2006
        • 1794
        #18
        If someone have been changed battery on nvm then you could not know how many copies machines have been done.
        If not you have counter.
        • Enzo
          • Jul 2009
          • 413
          #19
          Thanks friend but I am sure that the battery has not been changed. So where I can check how many copies made the machine?
          • xcopytech
            • Aug 2006
            • 1794
            #20
            on touch screen right side you have three buttons
            press 3rd button
            billing
            • livewire
              • Sep 2011
              • 608
              #21
              There are two ways to check the meter.
              WorkCentre 5645/5655 Online Support for How To Read the Meters (Billing Counters) | Xerox USA
              • Enzo
                • Jul 2009
                • 413
                #22
                Sorry friend but I already know these methods. Unfortunately, in this way I can not seem to know the real copies made!In a few options in the memory nvm it is possible to know the really copies made
                • xcopytech
                  • Aug 2006
                  • 1794
                  #23
                  As I told you before, if someone replaced batter earlier then you can not know real copy number.
                  If battery is replaced then nvm is reset to deful and copy number is reset to 0.
                  • Enzo
                    • Jul 2009
                    • 413
                    #24
                    But in my opinion has not changed the battery. It was only brought back several copies of the counter and I want to discover the real copies made.
                    • livewire
                      • Sep 2011
                      • 608
                      #25
                      these methods shown in the link below.
                      What displayed the total Impressions counter?
                      • Exok
                        • Jun 2011
                        • 750
                        #26
                        There is only one total counter. If it has been blanked (by removing the battery from the software module for a period then reinstalling or installation of a new software module) or changed (by installing a software module from another machine) there is no way of recovering the original counter data.
                        • Enzo
                          • Jul 2009
                          • 413
                          #27
                          Ok I have understood. I was hoping that there was a method to know the real copies made from the machine. I for example, I have a dc440 and by nvm property I can change the counter in order to make show a other number than that real.
                          • xcopytech
                            • Aug 2006
                            • 1794
                            #28
                            So, what you want to know?
                            How to change total counter?
                            Is that your question?
                            • Enzo
                              • Jul 2009
                              • 413
                              #29
                              Exactly! Basically I bought a used machine with 60k copies but in my opinion has done a lot more copies. I want to check this.
                              • livewire
                                • Sep 2011
                                • 608
                                #30
                                Check the Service History in the Machine Log Book.
                                Of course if there is.
