Xerox 4112 with Error Code 078-213
  • vishop
    • Jan 2011
    • 220
    Hi guyz,
    I have a Xerox with an error code of 078-213, and saying High Capacity Feeder problem
    Can anyone guide me as to what to check and how to approach this problem?
    Would really appreciate your help guys.
  • InterfaceP
    • Jun 2013
    • 488
    Re: Xerox 4112 with Error Code 078-213
    Check the code again. I don't find a 078-213.
    The High Cap feeders are usually easy to fix.
    • adriansto
      • 2388
      Check lifting mechanism of tray5 - MSI
      The MSI tray is lift up to slowly or dont lift up
      • vishop
        • Jan 2011
        • 220
        Yes interface, it is the code shown. In the user manual, it says,
        078-213 - Cause:
        Paper Tray 5 (Bypass) malfunctioned.
        Remedy:
        Power-cycle the machine. If the tray errors are not fixed by
        performing the relevant remedy, contact the Customer Support
        Center.
        I just need a little more detailed info as to what and how to check.
        • vishop
          • Jan 2011
          • 220
          Yeah, ill try to open up the covers and check on that.
          Thanks for the reply. Will get back on the outcome..
          • vishop
            • Jan 2011
            • 220
            Problem found.
            The gear of the motor for the lifting is broken.
            Glued and fixed
            Thanks guyz
