DC 545 Password
  • proflan
    • Jun 2025
    DC 545 Password
    Hi @ all I've bought an used Xerox DocumentCenter 545 at ebay. Unfortunately there is a password set. The default Password (1111) does not work - seems to been changed. I also made an firmware update using "lpr -Plp -S[IP] [filename]", but after the (successful) update the password has not been resetted to default ;-( Can anyone help?
  • xcopytech
    • Aug 2006
    • 1792
    enter in diagnostic and then go to other routines, select "001 Reset auditron master PIN"
    This will reset password to default 1111
    • proflan
      Hey xcopytech, thank you for your answer, but for that the pws software ist needed, isn't it?
      • xcopytech
        • Aug 2006
        • 1792
        Are you a tech???
        • proflan
          ok - i have it, thanks. I used BruteForce on the WebAdminInterface and solved the Problem. Thanks.
          • kevnbev
            try looking at the numbers that are worn out the most. I figured out the passwords on two machines that we purchased new by doing that.
