workcenter 5230
+ More Options
Posts
  • Eugenio Heitor
    [Misc] workcenter 5230
    hi
    i need to know the reason why a machine after turn on stays in ''pause'' mode and i can't get out of this situation
  • Exok
    • Jun 2011
    • 750
    Re: workcenter 5230
    I would need to know more information such as what you mean by "pause" mode.
    Does the machine boot up when you turn on the main power?
    If the machine does not power up, what if anything do you see lit up? What LEDs? Is the display screen black?
    Have you tried to reload the system software?
    If the machine does not power on at all, it could be the power supply.
    Is the main power switch behind the front door turned on?
    The more information you provide, the better we can determine what has gone wrong with your machine. Feel free to post photos of what you explain.
