Xerox ColorQube 9301 will not boot into UI, Machine Locked in UI
  • adriansto
    • 2392
    #16
    Re: Xerox ColorQube 9301 will not boot into UI, Machine Locked in UI
    Look at the papers which comes with the machine or look into the machine trays.
    May be you find a configuration report or test print with software version printed on it.
    • LamsterPaul
      • May 2014
      • 46
      #17
      Is there any preperation of the usb stick needed to make the usb stick bootable ?
      for make an altboot ?
      i have an pws laptop with gsm lock, but old, so it will not work on the newer colorqube
      pws 9.0 but no subcription for softwareupdate
      • LamsterPaul
        • May 2014
        • 46
        #18
        I've found some infos,
        the problem is allready in the post booting process, before the altboot can be initalized,
        i will test it out tommorrow and will look for the flashing code of the mainboard
        thank for help
        • LamsterPaul
          • May 2014
          • 46
          #19
          baybe I found the fault
          I have an flasing error in the POST faultcode at the Single Board Controller and on the IME Controller too
          it will says: 321 (ENG_SC_CONNECT_FAULT)
          CABLE Error and CPU error lamps off are off on the IME , ENGINE and Error-led will flashing the code
          that means:
          IME Blink Condition B
          in the ServiceManual there stand that I should replace the IME Controller PWS
          have someone an hint or an used IME Controller Around for sell ?
          on the Board is the Nummer: 960K58923 but at the Spare Part Catalog of the 9303 is a different number (960K66590) ?
          and how much can cost this unit ?
          thanks
          Paul
          • LamsterPaul
            • May 2014
            • 46
            #20
            Re: baybe I found the fault
            I've replace the imu board, but i have still the same error on it,
            Eng_sc_connect_fault 321
            it is an post fault, can i go to altboot wenn i have an post fault like this ?
            i've found a small gear on the upper paper tray in machine,
            have not found where there are missing yet,
            could this also produce this fault ?
            paul
            that means:
            thanks
            Paul
            • LamsterPaul
              • May 2014
              • 46
              #21
              I'm on the end, i've look all the diagnose procedures without any solution,
              altboot also will not work, because fault fast before initalize the altboot process
              the problem was allready in the POST,
              cable error ???
              is it possible, to connect direct into the UI with an PWS Laptop ?
              connector is available
              to upgrade, i think the problem is an software issue,
              I had an old PWS laptop for xerox 3535 and had peformed there also an update with success
              But had no diag software for the colorqube 9301
              And no gsm account for download it
              Have someone a hint or solution before i call the xerox custom support ?
              i hope that the travel and looking for the fault will not cost more that the machine is worth
              paul
              paul
              • LamsterPaul
                • May 2014
                • 46
                #22
                Have found the fault !
                it was a bad harddisk, i've replaced it,
                boot it will the PWS laptop und reinstalled the software, took near 2 days to find the i/o error of the hdd
                Had to make come calibrations and a loose gear and have now a working 9301 with 80.000 clicks for around 700usd, that was a good deal
                thanks for your help !
