Xerox ColorQube 9301 will not boot into UI, Machine Locked in UI
  • LamsterPaul
    • May 2014
    • 46
    [Dead] Xerox ColorQube 9301 will not boot into UI, Machine Locked in UI
  • Exok
    • Jun 2011
    • 750
    Re: Xerox ColorQube 9301 will not boot into UI, Machine Locked in UI
    Do an AltBoot software install via usb thumbdrive.
    • LamsterPaul
      • May 2014
      • 46
      • Flash
        • 378
        If this is a non Tag 6 machine you have to press 8 or 9 when the machine status button lights up for an Altboot to start.
        • dorez
          • Feb 2013
          • 73
          Originally posted by LamsterPaul
          t the USB stick will not reconised by the System.
          Is there an Spezial USB Stick needed of specially formatted ? (FAT ?)
          Paul
          What BRAND is your USB? I personally use Kingston has they have the BEST compatibility, formatting in FAT32.
          • LamsterPaul
            • May 2014
            • 46
            I also used a Kingston,
            only Format with FAT32 and the copy the files to the ALTBOOT dir ? schould work ?
            I have any sucess with this, trying around for hours,
            the Statuslamp with only blink and the Screen with Show the Xerox StartupScreen with Please Wait - Booting
            any hints or Solutions ?
            • dorez
              • Feb 2013
              • 73
              How many hard drives are installed?
              • LamsterPaul
                • May 2014
                • 46
                • LamsterPaul
                  • May 2014
                  • 46
                  I have also try to connect an new HDD wthout success
                  Require the ALTBOOT any other files to boot on the USB stick ? (Linux boot files etc ?)
                  is there an diagnose option on this machine, that can be startet at boot, by pressing a key or something ?
                  • adriansto
                    • 2392
                    Dont push too much with altboot procedure because you can brick your UI board.
                    Ther are many reasons for machine non booting. You need service manual and do a lot of checkings before loading software.
                    • LamsterPaul
                      • May 2014
                      • 46
                      • adriansto
                        • 2392
                        Send me mail
                        • LamsterPaul
                          • May 2014
                          • 46
                          • Exok
                            • Jun 2011
                            • 750
                            If you are going to do an AltBoot, make sure you are using the correct software depending on if your machine is connect key model or not.
                            061..... or 071..... I made the mistake of using 061 software on a connect key machine once and for a while couldnt figure out why the altboot wasnt working.
                            • LamsterPaul
                              • May 2014
                              • 46
                              That could be the problem, how can i see the difference of this two units ?
