Xerox WC5645 communication error
  • bojans
    • 1313
    I have Xerox WC5645 with SBC Tag 40.There are 5 dots on the screen and I'm trying to restore NVM.
    After connect PWS tool with machine it says "Opening connection with the device..." and then error
    Anyone had this problem? Could it be bad Software module?
  • adriansto
    • 2388
    Re: Xerox WC5645 communication error
    try to reinstall pws tool.
    If dont work remove battery from sw module for 10 minutes then put it back and try again
    • bojans
      • 1313
      Thank you.
      Allready tried that but without success.
      It cannot establish communication.
      • xcopytech
        • Aug 2006
        • 1794
        Replace software module.
        What version of Diagnostic you have?
        Need at least 25.00.008 version.
        • bojans
          • 1313
          Thanks.
          I have PWS Tool v25.00......
          I also suspect on software module...
          • xeroxsharp
            • Nov 2008
            • 270
            SW modul is bad.
            Regards
            • livewire
              • Sep 2011
              • 608
              Hi Bojan,
              try with another laptop.
              • adriansto
                • 2388
                Originally posted by livewire
                Hi Bojan,
                Be sure in this garden grow up a lots of laptops in many colours .
                Check if your laptop can connect with another 56xx machine. Very rare bad sw module.
                Also check the 3.3 volts in SIP module to be 3.3 - 3.5 volts no less
                • bojans
                  • 1313
                  Thank you all for your help.
                  I have tried with other laptop. Same situation. All voltages good.
                  I have to agree with Adi that this is very very rare, but seems that it's all about SW module.
                  I think i have one 5645 for parts but it's w\o tag 40, but when I checked documentation, it seems that these two models (with and without tag 40) dont have same software modul.
                  Will keep you up to date, but need time to get new SW module.
                  • walidcharifi
                    • Feb 2011
                    • 379
                    Originally posted by bojans
                    communication error.... on the picture[ATTACH=CONFIG]25538[/ATTACH]
                    i need pws for 5645
