Hello Guys,
I recently set up a workflow scan on a Xerox Workcentre 5755 for a client and although we're showing no errors at all, the file is NOT showing up in the created folder we set up. I'm also an IT professional, and I know my server settings and permissions are correct. I have followed the instructions verbatim in the "Getting Started Guide" under "Workflow Scanning".... Yet, I don't see my docs..
No errors, just seems to shoot it out into oblivion. I would appreciate the help from someone who may know what the problem is, or has had a similar experience and created a resolution...
Things to note:
It is SBS Server 2008 and the shared folder is on another drive other than the default "C" drive. The drive letter is F: for reference. We have assigned a user specifically for the copier, no luck. Changed the permissions on the folder to "everyone" and still have not had any success. Quite frankly I'm at a loss, so need your help...
Thanks in advance for any help you may be able to provide us.
Things to note:
