Xerox Phaser 7800 Fuser Temperature
+ More Options
Posts
  • Oscar57
    • 79
    Hi,
    Does anyone know if there is a adjustment for Fuser temperature on the Xerox Phaser 7800. I am having a issue with toner sticking to the paper. If I run a much heavier paper stock setting the toner sticks fine but slows the copier way down.
  • Tek_services
    • Jul 2014
    • 22
    Re: Xerox Phaser 7800 Fuser Temperature
    No error code????
    • Tek_services
      • Jul 2014
      • 22
      enter DC330 CODE 10-100 TO HEAT THE FUSER
      • Iowatech
        Not a service manager
        • 3930
        Originally posted by Oscar57
        Hi,
        It takes more time to properly fuse toner to heavier paper. The slow down is normal machine operation.
        • Exok
          • Jun 2011
          • 750
          What kind of paper are you using that you have having the trouble with?
          • MonsterBaby
            know what u are talkin about. im having the same problem!
            talked to some techs and had no resolution for it!.. did u find a way to solve the problem?
            do you use the original toner?
