Xerox 7835 ..."Reset Device"
  • Jhill2
    • Jul 2025
    [Misc] Xerox 7835 ..."Reset Device"
    This 7835 won't reset, It will NOT see a thumb-drive installed for a Alt-boot, Tried new SBC and fuser, it just says "Reset Device" after about 6 min. or so , Anybody seen this?
  • Flash
    • 378
    Re: Xerox 7835 ..."Reset Device"
    Try initializing NVMs. It should take a forced altboot That usually gets it back up and then you can use the self cloning feature to restore network settings
    • Jhill2
      It can't get that far, I have No access to NVM and won't acknowledge a USB device when plugged in. Most info. points to the SD card when this happens I've just found out, Thanks for the info anyway.
      • Exok
        • Jun 2011
        • 750
        Have you tried the USB port on the SBC for an AltBoot? The front port may not be active.
