Xerox Docu II C3000
  • NeoMatrix
    Senior Tech.
    • 3513
    Xerox Docu II C3000
    No manaul for this model.
    Error code on display 089-311
    Is this a ITB transfer belt error ?
    tnx
  • Nzer
    • Sep 2014
    • 34
    Re: Xerox Docu II C3000
    Yes is a Transfer belt error, it has two patches on the belt, sometimes the metal plate at the top of the regi chute is too close and will rub and damage the patches,needs a slight bend away from belt or on occasion if also have noise a bearing will come out of its flange which can be bent back into shape, with the belt out the sensor can be easily cleaned - sensor bar at left side
    Believe this model is a wc7132 in U.S docs
    • NeoMatrix
      Senior Tech.
      • 3513
      I had the ITB unit out of the machine completely.
      I cleaned the reg bar sensor. It does't appear to be rubbing as you say.
      The ITB rubber edge tracks inside the ITB itself have perished and rubber is missing in places.
      I clean the ITB best I could an placed it back in the machine.
      The machine cycles fine an then throws the same original error.
      What is the service code to clear the 089-311 error condition ?
      • Nzer
        • Sep 2014
        • 34
        There is no reset code - email me and I will send some info that may help grantt987@gmail.com
        • NeoMatrix
          Senior Tech.
          • 3513
          Thanks for the TB's. They gave me some other options to try.
          Neo
          • NeoMatrix
            Senior Tech.
            • 3513
            Any one have a service and parts manual for this machine? So I can come to speed on a couple of things.....
            I require ITB part number and/or ITB rego patchs.
            tnx....
