6204 U I
+ More Options
Posts
  • ahmed abdou
    • Feb 2014
    • 45
    6204 U I
    hello every body I have xerox wide format 6204 i change main pwb of CP controller i have problem in U I ( icon exist , no text in U I) can't download UI (text,font,icon) i reload firmware problem still exist THANKS
  • adriansto
    • 2383
    Re: 6204 U I
    What firmware version ?
    • ahmed abdou
      • Feb 2014
      • 45
      Re: 6204 U I
      i think the last one 1.2.0 thanks
      • adriansto
        • 2383
        Re: 6204 U I
        Is not the last one but it is ok like software version. I presume you used the network method not the usb method.
        Did you try to download the fonts and ... into UI after reloading software using the pws as you are instructed by service manual ?
        • ahmed abdou
          • Feb 2014
          • 45
          Re: 6204 U I
          Is not the last one but it is ok like software version. I presume you used the network method not the usb method. Did you try to download the fonts and ... into UI after reloading software using the pws as you are instructed by service manual ?
          thanks for your help yes i use 1st usb method than i used network method but i can 't use panel data download (text,font, icon) UI HANGS IN PANEL DATA DOWNLAOD
          • ahmed abdou
            • Feb 2014
            • 45
            Re: 6204 U I
            thanks for your help yes i use 1st usb method than i used network method but i can 't use panel data download (text,font, icon) UI HANGS IN PANEL DATA DOWNLOAD
            • adriansto
              • 2383
              Re: 6204 U I
              May be the ui is defect or ui part of the 12.0 firmware si bad
              Take a look and compare the files from panel directory from 1.2.00 NET version
              • ahmed abdou
                • Feb 2014
                • 45
                Re: 6204 U I
                [QUOTE=adriansto;439029]May be the ui is defect or ui part of the 12.0 firmware si bad Take a look and compare the files from panel directory from 1.2.00 NET version[/QUOTE THANKS A LOT I WILL CHECK
