xerox 700 connectivity problem
  • aparat
    • Jan 2012
    • 17
    HI, i have a problem with my xerox 700 - think something with connection (busteled fiery)
    I CAN print normaly from command workstation and from driver, works OK.
    BUT
    I can not connect to the fiery server via IP. I can not acces "server configuration" via CWS, and i cant acces web applications via UI.
    Allso the communication when i print with driver seems slow.
    What could it be?
  • adriansto
    • 2388
    Reinstall Fiery software.
    It's the quickly method.
    • InterfaceP
      • Jun 2013
      • 488
      Re: xerox 700 connectivity problem
      Make sure you have a crossover cable connected from the scan port on the Fiery to the net port on the 700.
      • aparat
        • Jan 2012
        • 17
        hi, cable is ok, network scanning is allso working
        • Exok
          • Jun 2011
          • 750
          I've seen this problem with a DC252. Even though the crossover cable worked when I tested it, replacing the crossover cable (then reboot) fixed the problem. This customer still has the issue pop up once in a while and they fix it by disconnecting both ends of the crossover cable, power the machine off, reconnect the crossover cable then power back on.
