DC240/DC242 CREO system software needed
  • imdabs
    [Misc] DC240/DC242 CREO system software needed
    Hi All,
    I have couple of DC240/242 and their CREO HDD has failed, So i need to replace HDD and put new system software..
    can Anyone help me with that??
    Either how to source a CD with Sytem software or copy system software from a good machine...
    Thanks in advance for your help.
    Regards
  • InterfaceP
    • Jun 2013
    • 488
    Re: DC240/DC242 CREO system software needed
    Stand alone or bustled?
    • Milo Wilson
      • 508
      I don't believe there are 2 different versions of creo. It is all the same type. The only difference is they sometimes mounted it to the back of the machine versus to a table monitor and keyboard assy.
      • imdabs
        bustled
        • alibear57
          • 14
          Don't know if I'm too late with this, but I have a DC242 with EX260 Fiery. I know there's a Fiery install folder on the Fiery hard drive but not sure of copying that onto a CD/DVD would be sufficient for your needs. If you have the know-how on what to do with this, if you, or anyone else, could send me instructions, I'd be happy to burn it onto a disc and send it to you if that would help.
          • alibear57
            • 14
            I replied to this thread earlier but it doesn't seem to have appeared on here. In the earlier reply I said that I had a DC242 connected to a Fiery EX260. I discovered a folder inside the C drive which contained the installation files for the Fiery software. I've used it to reinstall the Fiery software and it worked. If you, or anyone else, knows how I can burn the appropriate files from there onto a CD/DVD, then I will send you a copy of it - if you've not already got it from somewhere else.
            • imdabs
              thanks for trying to help.. but I am not looking for fiery (EFI) software... I am looking for creo software, Regards
              • InterfaceP
                • Jun 2013
                • 488
                I ran into a similar problem and searched for a solution for quite some time. I have the Creo disc but they dont contain a boot file.
                The solution that was given to me was to obtain an image of a working HDD and copy it to the HDD inside your Creo.
                I hope this helps.
                • simic0000
                  • May 2020
                  • 9
                  I have creo on my Xerox and my hdd is dead.
                  Can you please help me?
