xerox wc 6505n REPLACE TRANSFER UNIT
  • djwhoo
    • Aug 2013
    • 117
    apparently i have installed a new transfer unit assembly and the message on the ui will not clear. How to I reset it?
  • livewire
    • Sep 2011
    • 608
    Re: xerox wc 6505n REPLACE TRANSFER UNIT
    Do you have service manual?
    • Exok
      • Jun 2011
      • 750
      First, follow the steps in the user manual. Transfer belt reset is on page 225.
      Here is a link to the manual via xerox.com : http://www.support.xerox.com/support...ntentId=121958
      I've heard of a problem when the transfer unit counter wont reset. I hear doing a software upgrade fixes it.
      Here is a link to xerox.com's latest software release for your machine.
      WorkCentre 6605 File Download
      • djwhoo
        • Aug 2013
        • 117
        apparently my head tech talked to someone who did.It seems like you need to initialize the dtb waste after installation....which i did. stiill no go. Aside from checking voltages which we could not do because of no Service manual we did everything correct. Im not sure how it could be a bad transfer unit with only one patch sensor on it. I had a feeling that maybe the varistor on the right hinge maybe bad. I had no reisistance or continuity.
        I just dont know how to reset the Replace Transfer unit message. must be an NVM value. I could not find any parameter setting other than the dtb waste. Stumped. btw... it was a customer supplied transfer unit. probably an ebay deal.
        • djwhoo
          • Aug 2013
          • 117
          I cant seem to find transfer belt reset in the user manual. page 225 is canadian regulations in my copy..
          could you provide me a link or screen shot? ericbrustad@gmail.com
          also... which software? Do you mean the firmware of the machine? I saw no firmware listed under workcentre 6505.
          Thanks.
          • djwhoo
            • Aug 2013
            • 117
            the links on my end ended up at a default search screen for xerox.. It wasnt 6505 specific.
            • Scarecrow
              • Oct 2010
              • 234
              Eric, I'll be sending you a manual (pdf) hopefully tomorrow. 60 mgs. If you need anything in the manual, just call. But the belt reset procedure is not there. It does say to to a reset after installation. The reset procedure for the fuser is there however. Mr. J evidently found the same belt reset procedure that is @ Xerox.com, but it still won't reset. Strange that it's not in the manual - at least we couldn't find it.
              Glenn
              • djwhoo
                • Aug 2013
                • 117
                Glenn
                Thanks.. I greatly appreciate it.
                • adriansto
                  • 2383
                  Press Machine Status button
                  Tools - Admin settings - Service Tools - Reset transfer Unit.
                  Sometimes dont work if the firmware is lower than 2.00.06 so the solution is to upgrade the firmware.
                  • Exok
                    • Jun 2011
                    • 750
                    You can download the user manual from xerox.com
                    Here is the section I was talking about:
                    Resetting the Transfer Unit
                    The print meter keeps a count of the pages processed by the Transfer Unit. As the page count nears the
                    end of life for the transfer unit, a message appears to warn you to replace it soon. After the transfer unit
                    is replaced, reset the transfer unit so that the printer has an accurate page count for the new unit.
                    To reset the transfer unit:
                    1. At the printer control panel, press the Machine Status button.
                    2. Touch Tools>Admin Settings.
                    3. Using the keypad, type the passcode as needed.
                    4. Touch Service Tools.
                    5. Touch Reset Transfer Unit.
                    6. Touch Reset>Yes, Reset.
                    To cancel, touch the X button or select No, Cancel.
                    7. To return to the Service Tools menu, press the Back arrow. To return to the Services Home menu,
                    press the Services Home button.
                    • djwhoo
                      • Aug 2013
                      • 117
                      The screen wouldnt even come up. all buttons are locked out ( no response).
                      on screen "REPLACE TRANSFER UNIT"
                      arrows up and down on power up. parameters--dtb waste--- initialize-- showed like 4268378.. 4 million? and change.. the number i showed wasnt exact but..? wierd.. all other settings show "-1".
                      We are leaning towards the mcu pwb. the machine is totalled.
                      not worth it anymore.. Thanks for all your help guys !! it is Greatly appreciated
                      • djwhoo
                        • Aug 2013
                        • 117
                        i couldnt find the firmware on the xerox website? Did I miss it?
                        • adriansto
                          • 2383
                          It isn't. Send me mail
                          Sent from my V3-E using Tapatalk
                          • djwhoo
                            • Aug 2013
                            • 117
                            Customer is going to buy another machine. Its not worth fixing it. Though I am obsessing about what the problem is. ha..
                            Thanks for your help
                            • Exok
                              • Jun 2011
                              • 750
                              I just ran into this same problem this week. Upgrading the machine software fixed it. With the original software I was able to get into the service mode and reset the correct counter but it still did not clear the message. After upgrading the software and going back into service mode and resetting the counter again fixed the problem.
                              Note*
                              The software is split into 2 different files, 1 for the print engine and 1 for the controller.
                              Update both but only the engine software fixes this particular problem.
