xerox wc 6505n REPLACE TRANSFER UNIT
  • djwhoo
    • Aug 2013
    • 117
    #16
    Re: xerox wc 6505n REPLACE TRANSFER UNIT
    Originally posted by Exok
    I just ran into this same problem this week. Upgrading the machine software fixed it. With the original software I was able to get into the service mode and reset the correct counter but it still did not clear the message. After upgrading the software and going back into service mode and resetting the counter again fixed the problem.
    Note*
    The software is split into 2 different files, 1 for the print engine and 1 for the controller.
    Update both but only the engine software fixes this particular problem.
    could you send me the software? ericbrustad@gmail.com
    • Exok
      • Jun 2011
      • 750
      #17
      Cant get the links on the forum so I'll send you the bulletins that contain the links to download the software.
      • karl_frederick
        • 8
        #18
        Please try with this public link...
        WorkCentre 6505 v201203141124
        ht**p://www.support.xerox.com/support/_all-products/file-download/enus.html?contentId=121588
        In my case I upgraded the firmware, go again to reset Waste again, but the IBT waste counter still freezed in 4.155 millions ...
        If any guys knows how to change this value from NVM settings, please share.
        Thanks in advance,
        Regards
        Karl
        • fou�
          #19
          Hi, I tried the firmware upgrade 201203141124, it doesn't solve the problem.
          (Cannot reset Life WTB Waste after transfert unit change).
          (REPLACE TRANSFERT UNIT on screen, buttons unresponsive)
          Could you send me the software please ? f.lormand@outlook.fr
          Originally posted by adriansto
          It isn't. Send me mail
          Sent from my V3-E using Tapatalk
          • karl_frederick
            • 8
            #20
            Finally in my case I had to replace the SFP MCU Board and SFP EEPROM Board from a Xerox 6500 (more than cheap 6505 mfp) because the printer never goes into to initial menu always stuck on " replace transfer belt".
            After replaced the boards from 6500 printer... the 6505 SFP works well.
            You must change booth boards (2) because I changed only the MCU board first and the machine shows "firmware error".
            Hopes this help you.
            Regards
            • Albonline
              • Sep 2008
              • 1151
              #21
              am dealing with this reset belt problem also cant find the correct firmware on xerox site, any help? anybody?
