machine not booting
  • Reeves
    • Apr 2012
    • 295
    [Misc] machine not booting
    i have a xerox wc5655 copier which is not booting when i switch on it ll came on just 5 dots thats all i have tried to remove the memory then put back the plobrem is the same pliz advice
  • bojans
    • 1313
    Re: machine not booting
    Did you try to restore NVM?
    It seems that is common problem to this series. I have couple with bad NVM Pwb's, but it could be drained battery. So first try to restore NVM.
    There is default nvm file if you dont have floppy disk...
    • Exok
      • Jun 2011
      • 750
      Try to do an AltBoot.
