Re: XEROX 7545 lost speed. It show 7525...On boot ..Device not work
Just fixed one of 75xx with same problem ( UI show diferent speed ).
New FLASH ROM,new HDD and altboot did not fix this issue.
Bad SBC was the problem.
-I replaced SBC PWB and battery on FLASH MODUL and I did ALTBOOT.
-You will loose all counters. Everything will start again from zero
-The device after altboot end few restarts go to NON CUSTOMRE MODE
-Use DC 131 nvm 616-014 set from 0 to 2 ( install phase compleate ).
-Finaly you do install procedure.
Hope this will help
br
Hope this will help
br
