XEROX 7545 lost speed. It show 7525...On boot ..Device not work
  • OLEOLE
    • Oct 2014
    • 8
    [Dead] XEROX 7545 lost speed. It show 7525...On boot ..Device not work
    My XEROX 7545 lost speed. It show 7525...On boot ..Device not work
    I try firmware altboot 3 time not work .....
    How can i do......?????
  • adriansto
    • 2388
    Re: XEROX 7545 lost speed. It show 7525...On boot ..Device not work
    Nice !
    What software version ?
    Go to UI diagnostic, enter dc301 and select copier on the left, print engine in center, ALL on the right.
    Do not restore nvm's saved before with dc361
    • OLEOLE
      • Oct 2014
      • 8
      SW version == WorkCentre_7500-system-sw#06112122206508#.DLM
      My process ...
      1.unpack battery from "960K65323"
      2.short circuit
      3.format HDD with PC..
      4.Everything lost......OMG...
      5.try firmware altboot 3 time...not work ...
      6.Boot show 7525
      7. Show error 341-371-00, 322-352-00
      8.Wait.....from someone help me...
      • adriansto
        • 2388
        I think you know what 322-352 error code mean.... So only from xerox you can wait for help
        • OLEOLE
          • Oct 2014
          • 8
          LOL..
          ........i can not call to xerox USA .....I think so. I want simcard for solv problem
          PLS advice me . If has other way...
          • adriansto
            • 2388
            Originally posted by OLEOLE
            LOL..
            Not the simcard is the first problem. You loose serial, speed and meters.
            You can try the service manual procedure for 322-352 code but always you finish with dc132.
            • OLEOLE
              • Oct 2014
              • 8
              i buy device in thailand. It second hand devices from USA. not warranty..by xerox
              If...I have another one same machines (7545). can copy or recover "960K65323" YES or NO
              • adriansto
                • 2388
                If this second machine is operational you can try to put 960K pwb from nonworking machine inTO the operational machine. If 960k is good the operational machine will work. If 960k is bad you cant recover it.
                Put back the original 960K in the operational machine.
                • OLEOLE
                  • Oct 2014
                  • 8
                  thank you for advice. machine can recover.
                  But it is show "a power on failure" on screen. Try altboot many time. it can't solve How can i do it
                  #. I have PWS-Diag-V3.6 :: PWS V 9.2 for WinXP and PWSCRACK
                  #. I try PWS Diag V3.6 connect WC 7545 and 4110 ..With USB cable. not work ???
                  #. If you has any way for use PWS pls. tell me
                  #. I want E-DOC WC 7500
                  • adriansto
                    • 2388
                    This machine has builtin diagnostic. No external diagnostic or pws tool.
                    Only altboot from pws but you need an unusual serial cable for that.
                    For edoc you can send me mail at stoadis@gmail.com
                    • mkdirs
                      • Oct 2014
                      • 177
                      NVM save and restore with PWS NVM Save & Restore tool
                      download the Attachments file for your Xerox
                      Sory this solution for wc 57xx not for 75xx
                      Xerotk.com
                      xerox copier technician
                      • adriansto
                        • 2388
                        Mkdirs you are a nice person but we talk here about WC75xx colour machine not WC57xx black and white
                        • mkdirs
                          • Oct 2014
                          • 177
                          Ops am sory man
                          i think that i have the solution let me chick for that and i will replay for you
                          Xerotk.com
                          • mkdirs
                            • Oct 2014
                            • 177
                            My process ...
                            2.short circuit
                            6.Boot show 7525
                            back
                            get lock on the attachments
                            first question in img 75xx if this the NVM that you unpack battery ?
                            second question in img 75xx 2 you need to insert the Xerox SIM for speed sittings
                            did you look for the SIM CARD in try 1 or try 2 in Hideaway Place ??
                            in the 322-352 code
                            Serial number data is stored at three locations:
                            MCU NVM PWB
                            SBC NVM PWB
                            IIT/IPS PWB.
                            in the information Button can you see any serial number ??
                            Xerotk.com
                            • shiva
                              Re: XEROX wc5755 pws tool
                              how can i get xerox wc5755 pws tool.
                              pls help me
