Fuji xerox wc7245 error code 006-381
  • Hong1007
    • Nov 2013
    • 41
    [Error Code] Fuji xerox wc7245 error code 006-381
    Hi all friend,
    I hv 1 machine fuji xerox wc7245 error code 006-381,
    That is a ROS ( laser ) fault. But where area i want to check??
  • Exok
    • Jun 2011
    • 750
    Re: Fuji xerox wc7245 error code 006-381
    I don't see that error code in the edoc.
    061 codes are ROS faults. I don't even see a 61-381.
    • adriansto
      • 2387
      Exok, 7245 is from WC73xx machine class not from WC7242
      Check PJ 401 -B20 from MCU pwb/ Must have 5 volts between that pin and machine ground. If not then MCU = defect.
      If ok check the wire between PJ 528, PJ 517 pin 1 from ROS to same PJ 401 from MCU.
      IF ok then change the ROS
      • framza1
        • Nov 2014
        • 5
