xerox 7675 odio
  • patrick045
    • Sep 2010
    • 38
    xerox 7675 odio
    Hi ,
    Can any one give me the odio procedure for this model , we need to wipe the hard disk .
    Thx in advance !
    Pat
  • Flash
    • 378
    Re: xerox 7675 odio
    Press Machine Status, Tools, Security Settings, Image Overwrite Security, On Demand Overwrite.
    • patrick045
      • Sep 2010
      • 38
      Re: xerox 7675 odio
      After pressing tools i only see device settings , no security settings
      • Exok
        • Jun 2011
        • 750
        Re: xerox 7675 odio
        You have to log in as the administrator. When logged in as the admin, you will have many more options available in tools.
        login=admin
        password=1111
        • patrick045
          • Sep 2010
          • 38
          Re: xerox 7675 odio
          login=admin
          password=1111
          The previous owner changed the login code , admin and 1111 does not work
          • patrick045
            • Sep 2010
            • 38
            Re: xerox 7675 odio
            so if anyone can help me with password reset procedure would be appreciated .
            thx
            • adriansto
              • 2388
              Re: xerox 7675 odio
              Is not so simple. What software version is on the machine ?
              Do you want a working machine after hdd wipe or your need is to remove any informations from hdd ?
              • patrick045
                • Sep 2010
                • 38
                Re: xerox 7675 odio
                i have odio procedure en password reset procedure for all models except for this model .
                clearly i need a working machine after wipe , we want to sell it , but all information has to be deleted .
                i can check software version tomorrow .
                thx for the reply
                • adriansto
                  • 2388
                  Re: xerox 7675 odio
                  In this situation you need diagnostic software for the machine.
                  For several software versions the only way to reset admin passwd is to reload machine software.
                  • patrick045
                    • Sep 2010
                    • 38
                    Re: xerox 7675 odio
                    software version if i remember correct 40.33.xxx
                    • adriansto
                      • 2388
                      Re: xerox 7675 odio
                      xxx is the relevant information
