Cleaning a DC250 color drum
  • steveclv
    • May 2014
    • 95
    I have a light patch on the edge of the print that I think is being caused by an errant fingerprint (oops) on one of my color drums. I have researched Google and found conflicting information regarding cleaning - one page said use a tightly rolled up piece of paper and another said to use 99% isopropyl alcohol and a lint free cloth
    As I just want to remove the fingerprint from the edge of the roller, would the alcohol work or it would it instantly destroy the surface?
    I have new drums on their way, but it will take a couple of weeks before they get here.
  • Flash
    • 378
    Re: Cleaning a DC250 color drum
    You can clean it with alcohol.
      • 23006
      If this is an organic drum you're limited to paraffin lamp oil or alcohol (or Dispersant if any of that is still around). The lamp oil is great for adhesives, like labels, but must be rinsed off with alcohol before you re-prime the blade. =^..^=
