need help
  • kachou72
    • Jul 2025
    [Misc] need help
    I put two pictures attached. I have a concern about the cyan and black. I changed everything, developer, drum ... and it persists. Could you help me please?
    DC 240
    • 23008
    Re: need help
    Apparently you haven't changed everything, because the problem persists.
    I don't know that much about Xerox specifically, but I would concentrate on primary transfer black or developing black.
    Perhaps you're experiencing primary transfer loss, or losing black developer agitation or bias current. On most of the machines I work on, all the colors use one developer drive motor, and the black uses a separate drive motor. =^..^=
    • Iowatech
      Not a service manager
      • 3930
      Re: need help
      The model of the machine you require help for is?
      • imihm
        • Feb 2014
        • 77
        Re: need help
        DC 240
        Hello there
        Change developer material for both black and cyan
        • kachou72
          Re: need help
          The machine is Xerox Docucolor DC 252 and i have change Developer house, developer, drum, ....
