Xerox DC 250 Fiery software v.1.2
  • bojans
    • 1313
    Hi,
    Does anyone have it uploaded? And wiling to share.
  • InterfaceP
    • Jun 2013
    • 488
    Re: Xerox DC 250 Fiery software v.1.2
    I have v1.0
    • bojans
      • 1313
      Thank you,
      I have it, too.
      • Milo Wilson
        • 502
        I have 1.2 just need some time to put it on my server for you. this is bustled you're looking for, right?
        • bojans
          • 1313
          Thank you Milo,
          I got it in the meantime.
          Best Regards
          • adeyemi
            • 378
            Kindly send me an upload link for this EX250 system software too...i appreciate in advance. I need for the external not bustled fiery, thanks
            Dgtal
            • bojans
              • 1313
              This thread isn't for EXP software, but for bustled.
              Also when looking for exp, you must know software version. There are v1.1 and v1.01
              • adeyemi
                • 378
                Any version i get will be ok and i know whoever can discuss bustled would likely have the external software in their possession.
                Dgtal
                • simple mind
                  • Aug 2009
                  • 39
                  Hi,
                  Could you be kind to share it again,it has been a long time I'm looking for it .
                  Thanks.
                  Question: Does it fix the 45-314 fault code ? have it on my machine all the time DC240 V1.1 even with the patch installed.Weired things !!
                  • izcuintle
                    • 6
                    Would you share the Software the version I have is 1.0 but the disc is damaged. thank you
                    • Jp@docuflow.ie
                      • Nov 2015
                      • 13
                      I don't suppose you still have the bustled software 1.1 or 1.2 to share? I have tried to load v1.0 onto 2 fiery units with 3 new discs but it always fails at 733kb. I have heard that if the fiery was previously on a newer version you can't go back to 1.0. I came into these fiery units at the 260 and they always reload with no problem, as do Ricoh, canon etc.
                      Any advice would be appreciated. Thanks
                      • bojans
                        • 1313
                        Did you try to reload with other laptop?
                        I had problems with several laptops, Antivirus programs, you should also disable WiFi...
                        As far as I remember version 1.1 and 1.2 are for DC 250, and you're talking about DC 260 which has other software.
                        So, please let me know what machine we are talking about.
                        • Jp@docuflow.ie
                          • Nov 2015
                          • 13
                          • bojans
                            • 1313
                            I suppose that this is your email: Jp@docuflow.ie
                            I had similar problem recently on DC 250. Couldn't reload software on Fiery. In my case it eas problem with power supply on fiery, but there could be many other reason.
                            Sending you 1.2 soft
                            • Jp@docuflow.ie
                              • Nov 2015
                              • 13
