WC 7775 - Not printing yellow?
  • themountainecho
    • Dec 2011
    • 43
    Hi All,
    Got a 7775 that started displaying 'There is a problem with the xerographic system. Please call for assistance'. Swapped out the drums and toners one by one and after changing the Cyan toner it started printing again but noz Yellow won't print. C, M and K all come out fine, bu twith no yellow greens come out blue, etc. There is a small band down one side of the prints where yellow is present (please see image) but that's it. Have tried different yellow drums and toners, no dice.
    Any ideas?
    Thanks in advance
  • InterfaceP
    • Jun 2013
    • 488
    Re: WC 7775 - Not printing yellow?
    Make a copy of something yellow and do a hard stop. Pull the IBT belt out and check for an image.
    The cause could be several things. My initial thought was that maybe the drum was not seated correctly in the R4 slot. Thus only making contact with the IBT belt on one side.
    • lion_heart
      • Jun 2014
      • 174
      Originally posted by themountainecho
      Hi All,
      Any ideas?
      Thanks in advance
      [ATTACH=CONFIG]28047[/ATTACH]
      what's the exact error code? could be dispesner not pushing yellow from toner, could be a few other things, get back with error code, thanks
      • themountainecho
        • Dec 2011
        • 43
        Thanks for the replies. There is no current error code. As far as the machine is concerned it's printing fine :/
        No yellow on the IBT Belt when checked after a hard stop, so I'm guessing something with the dispenser.
        • themountainecho
          • Dec 2011
          • 43
          Now saying copying and printing not available but no current error code.
          • mkdirs
            • Oct 2014
            • 177
            check the Bracket in yellow Developer Housing
            or ATC Cover
            * then # then stop without release fingers pass 6789 to get the error code
            Xerotk.com
            xerox copier technician
            • lion_heart
              • Jun 2014
              • 174
              there is a code if it's saying printing not available,
              Fault 093-314 (393-314) for Yellow resets with 762-312
              Fault 093-315 (393-315) for Magenta reset with 762-313
              Fault 093-316 (393-316) for Cyan resets with 762-314
              Fault 093-317 (393-317) for Black resets with 762-315
              • lion_heart
                • Jun 2014
                • 174
                also, developer gears could be stripped or jammed, need to check those also or dispenser gears.
                • lion_heart
                  • Jun 2014
                  • 174
                  checking to see if you got it sorted out, and if you did, what was solution. thanks
