WC 5755 Misfeed indication in Document feeder
  • fbkhan3
    • May 2012
    • 421
    have cleaned both of these marked sensors as seen in attachment but still can't get rid of misfeed indication in Document feeder area.for the moment i have unplugged the Document feeder so costumer can make copies through scanner glass.
    kindly suggest.
    Thanks & Regard's
  • Corder
    • Nov 2014
    • 105
    Re: WC 5755 Misfeed indication in Document feeder
    And what jam chainlink do you have? There in the DADH more than two sensors.
    • Flash
      • 378
      Check the two in the top cover. The one on the bottom usually gets dislodged.
      • fbkhan3
        • May 2012
        • 421
        My bad i forgot to check the fault history and chain link Thanks for pointing me to the right direction.
        Did anyone came across this issue before specially with this model?
        Regard's
        • adriansto
          • 2376
          Remove the rollers kit from DADF and check it. Check if the gears from this kit are ok
          When put the kit back be sure it is in corect position so the rollers can be rotated by the drive mechanism.
          I think your problem is the rollers dont rotate and dont feed the paper bcause the kit is misplaced.
          • fbkhan3
            • May 2012
            • 421
            Really appreciate that adriansto,i'll look for that in next visit but does it really generates a continuous misfeed indication if anything wrong with that feeding kit or it will only create problem when paper feeding?
            Regard's
            • Corder
              • Nov 2014
              • 105
              Regard's
              Only when feeding.
              By the way, have you checked jam log? And if so what is the chain link?
              • fbkhan3
                • May 2012
                • 421
                Originally posted by Corder
                Only when feeding.
                Thank a ton guys for all your inputs I may have a visit there tomorrow and ill keep you guys update regarding the issue.
                Regard's
